Latest: williamekstrom
Overall: 17124
Online Now [101]:
Visitors: 100
Today: 7003
Total: 99339040
Forums › The Car › 206 Problems › 206 gti 180 gearbox
206 gti 180 gearbox
Samfry7790
PostPosted: Mon Aug 03, 2015 7:51 am Up
Do any over gearboxes fit a 180 other than an rfk?
PostPosted: Mon Aug 03, 2015 8:16 am Up
Rfk is an engine not a gearbox.
Samfry7790
PostPosted: Mon Aug 03, 2015 8:21 am Up
Ok not sure of code for box. Is there any other gearbox that will fit?
Project2062014
PostPosted: Mon Aug 03, 2015 9:34 am Up
BE4 gearbox, im sure others will fit if its off a ew engine but the gear shift's are cable on a 180 .metal on a gti 1.9d ect .
So will the gear shift housing white plastic bit fit on another box ?
Is the diff the same ?
Driveshaft the same ?
Samfry7790
PostPosted: Mon Aug 03, 2015 9:39 am Up
What's that off of?
PostPosted: Mon Aug 03, 2015 10:31 am Up
No others will be the same. 307 cc 180s may fit but the ratios may be wrong
Whats wrong with your current gearbox?
Samfry7790
PostPosted: Mon Aug 03, 2015 2:15 pm Up
I've got 2 cars 1 the diffs gone the over the lay shaft. How easy is it to change parts on these boxes?
existenz
PostPosted: Mon Aug 03, 2015 4:28 pm Up
If you need a Diff of a GTI 180 PM me. I have one left (80.000km).
PostPosted: Tue Aug 04, 2015 3:36 am Up
I have a spare diff, and could do it. I will need to fiqure out a price though
gpvecchi
PostPosted: Tue Aug 04, 2015 2:36 pm Up
Blown diff? Time for a Quaife!
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
