Online Now [286]:
Visitors: 285
Today: 103759
Total: 142614086
Forums › The Car › 206 Talk › Air intake
Air intake
Suggy
PostPosted: Sun Aug 09, 2015 1:02 pm Up
Anyone fitted one off these
www.ebay.co.uk/itm/251...EBIDX%3AIT
Opinions and ratings please! 1.4 16v A/C if so where did you mount the air intake at the front of the car?
Shadowstalke
PostPosted: Mon Aug 10, 2015 10:43 am Up
What are you looking for? More power or more noise?
If power, stay clear, I have heard these actually reduce bhp (or at least do sod all for it)
If noise then it'll do that. Mount it somewhere it will get cold air, but not take in water - behind the headlight is a good place, or above and slightly infront of the radiator. Just keep the open end away from the exhaust manifold and engine and it will be ok.
1.6HDi. Pull like a train. Smokes like one too!
No Smoke, No Poke!
Suggy
PostPosted: Mon Aug 10, 2015 11:04 am Up
Power, not really. Noise not bothered all though it would be nice to be able to here the engine (hard off hearing). Just want to free up some space so I can fit an oil catch can. I wouldn’t bother with the so called turbo fan that some seem to sell with them.
What would you recommend instead? if there is an alternative
Lex206
PostPosted: Mon Aug 10, 2015 2:03 pm Up
its all pretty much the same though;think if you dont want to loose hp its best to make sure the cold air feed is in the correct place.
ive tried the turbo fan as well and believe it or not it does actually spin..but only at high revs..
Megane 225 RS
David1156
PostPosted: Mon Aug 10, 2015 3:30 pm Up
If you're after noise, you'd be better off drilling some holes in the original airbox
Current: Albi Blue Clio 197
Suggy
PostPosted: Mon Aug 10, 2015 5:04 pm Up
More to free up space so I can fit an oil catch can.
I know if I want more hp I need to replace the exhaust system ( more it more out) just want the space. After all its only a 1.4
Shadowstalke
PostPosted: Tue Aug 11, 2015 6:16 am Up
If more space a cone is probably the best way forward, just make sure it is situated as far away from the radiator and the engine as possible!
No Smoke, No Poke!
