Latest: S2cgm
Overall: 17178
Online Now [1050]:
Visitors: 1049
Today: 114046
Total: 135787440
Forums › The Car › 206 Talk › Carbon Fibre bonnet on ebay
mattymj
PostPosted: Mon Aug 17, 2015 2:46 pm Up
What do you all think of this?
I wonder if it's in too bad condition.
Ebay link
Pezlah
PostPosted: Mon Aug 17, 2015 3:02 pm Up
Needs some work that. Relaquer it, it will come up good I would have thought Smile
Pezlah
Vexs
PostPosted: Tue Aug 18, 2015 12:45 am Up
Way to damaged, the white marks don't appear to be lacquer peal alone and look to be deep marks which if it is and has hit the weave then it's only good for the bin.
My GTI 180
My Old 1.4 8v
McGuiverNL
PostPosted: Tue Aug 18, 2015 3:08 am Up
Looks like you could save it with the right resin, varnish and polish...
2005 LHD black RC (GTi180)
Project2062014
PostPosted: Tue Aug 18, 2015 5:12 am Up
It's been on eBay time & time again over the last 2 year's .
Don't touch it .
Shadowstalke
PostPosted: Tue Aug 18, 2015 6:06 am Up
If it were on for 30 quid it would be worth a punt. I work in composites and most of that is surface damage and easy to clean up - remove the clear coat and relacquer (once you have recoated in in a protective layer of course). The bigger problem is the damage in the 3rd pic. Looking at cutting a fair bit of that structure out to put a repair patch in, and you will need a heat blanket to cure the repair, as I don't know what resin system they have used but if they are selling it for 90 quid I doubt it would hold up to a cure cycle heat in an oven.
1.6HDi. Pull like a train. Smokes like one too!
No Smoke, No Poke!
