Latest: lio94
Overall: 17181
Online Now [170]:
Visitors: 169
Today: 25652
Total: 141581043
Forums › The Car › 206 Talk › Fitting electric wing mirrors?
02fostb
PostPosted: Wed Aug 19, 2015 8:35 am Up
Is it possible to upgrade standard stalk wing mirrors to electric ones? Is it as simple as getting two wing mirrors with wiring and the centre switch and wiring them in?
mtempsch
PostPosted: Wed Aug 19, 2015 10:14 am Up
Essentially, yes. You might already have the extra plug under the window switch and wiring running up to the corner of the window - check.
If not, in addition to running that wiring, you might need to provide new power and ground to the switch as well.
The connector up by the mirrors can be different, so make sure you get mirrors with a plug fitting the harness connectors. Otherwise it's been said here that the pin numbering transfers between the different style plugs (3x3 vs 2x5), so it's fairly simple to change the plugs or make up adapters.
Silvermetallic 2004 206 RC
02fostb
PostPosted: Wed Aug 19, 2015 11:00 am Up
There's a breakers yard near me where you can help yourself and they have loads of Pugs in there, so was thinking of having the set from one of them!
02fostb
mtempsch
PostPosted: Wed Aug 19, 2015 11:04 am Up
Go for it! Get it all from the same car and you should have no problems.Don't forget the covers... Smile
02fostb
PostPosted: Wed Aug 19, 2015 11:05 am Up
I was more concerned with how the switch is wired in, does it literally just need a power supply?
02fostb
mtempsch
PostPosted: Wed Aug 19, 2015 11:16 am Up
It takes in +12 and ground and the switch movement then applies those to the wires to the appropriate motor, depending if you move horizontally or vertically. Polarity determining direction of movement on the chosen axis.
Don't recall how the heater element is powered in the case of heated mirrors though. You might want to see if the wiring diagrams in the Howto section covers that.
iainlovatt
PostPosted: Sat Aug 20, 2016 7:22 pm Up
I wired in electric mirrors into my 1.1 many years ago.
Do recall it being very difficult at all.
(My Garage)
copey
PostPosted: Sat Sep 03, 2016 3:06 pm Up
swap the looms and fit a switch and mine worked.......until some p***k decided to smash it off the car last night
02 2.0 hdi d turbo
iainlovatt
PostPosted: Mon Sep 05, 2016 2:39 pm Up
oh dear..
(My Garage)
copey
PostPosted: Wed Sep 07, 2016 9:15 pm Up
iainlovatt wrote:
oh dear..
had an old spare set with different colour plugs.....managed to swap the bass over and get em back working...after an hour an a half of labour, only bought the 180 mirrors a few months back
02 2.0 hdi d turbo
Ericjohnwade1985
PostPosted: Wed Nov 16, 2016 10:57 am Up
Hello just picked up a 2001 1.6 16v glx.
Looks like in past both mirrors been replaced.
One was broken too. There is a electric mirror switch in the car but one mirror was manual and one electric which I needed to replace. The mirror I took off had a round connector and a wiring harness clip, the same as the car. But the one I bought off ebay has a different harness adapter and no round connector. Do I need to get another mirror or is it fixable with a harness. Plus what is the round connector for.
Cheers
mtempsch
PostPosted: Wed Nov 16, 2016 1:41 pm Up
Cheers
The two types of connectors I've heard of have their pins in different arrangements, 2 rows of 5 or 3 rows of 3. Pin assignments are the same though, so the wire ion pin1 on a 3x3 is the same as pin1 on a 2x5, and so on.
Neither is what I'd call round though...
Pics?
Ericjohnwade1985
PostPosted: Wed Nov 16, 2016 3:49 pm Up
OK. Thanks. The round connector is a speaker I believe. Was dark this morn so could see it clearly. Cheers.
MrWhite
PostPosted: Tue Nov 29, 2016 3:31 pm Up
I could do with sole help with fitting mine as they are in and still will not fold. trying to find a solution can someone inbox me?.
My 206 Project Thread
mtempsch
PostPosted: Tue Nov 29, 2016 3:46 pm Up
Do you get 12V across pins 8 & 9, switching polarity as you rotate the switch between the forward and rear positions?
