Forums › The Car › 206 Talk › Hdi clocks |
Posted: Mon Aug 24, 2015 4:14 pm |
So for he past year I spent with a dodgy speedo saying 20 when doing 40mph, Dealer said it needs new dash set for £1000 fitted, they said I can get second hand but has to be a set serial number. Is this the case??
Thanks in advance
Posted: Tue Aug 25, 2015 12:44 am |
Avoid Peugeot dealers with old cars.
Posted: Tue Aug 25, 2015 1:07 am |
J18BES wrote: |
Thanks in advance |
Did he offer any free lube when he decided he was going to bend you over the counter or was that a paid extra?
£1000... jesus christ.
Posted: Tue Aug 25, 2015 3:59 am |
Haha this is pure comedy .
Speedos gone, New dash £1000
who & where is this man , name a shame him !
You only need new clocks probably .
What measures the mph is a plastic bit that slots on the end of the driveshaft £5 at the most..
Definitely not the dash set?
Fix it yourself source the parts.
| If it aint broke dont fix it ! | |
