Online Now [259]:
Visitors: 258
Today: 92697
Total: 143401580
Forums › The Car › 206 Problems › No central lock, wipers, indicators :(
Bahaie
PostPosted: Wed Sep 30, 2015 6:13 am Up
Hi All,
Yesterday suddenly I was opening the car, the central lock was working fine, after a while I got out of the car and closed the car using the key, this was the moment that everything went wrong and the indicators lights went on (not blinking) were just lead, I quickly removed the battery cables because I feared that something might get fried. Confused
When I reconnected the battery again, the indicators, wipers, and central lock were not working. Mad
But the electric windows, mirrors, AC & CD are working fine.
Can someone tell me what happened, and what should I do now? Confused Confused
gazza82
PostPosted: Wed Sep 30, 2015 11:37 am Up
Check fuses ...
You could try reconnecting the battery following the correct procedure .. search on here and it will all be explained. Connecting it incorrectly causes all sorts of BSI funnies
