Online Now [1414]:
Visitors: 1413
Today: 389475
Total: 153786381
Forums › The Car › 206 Talk › ew12j4 inlet manifold on a 180?
Forum Index › 206 Talk
Project2062014
PostPosted: Sun Apr 05, 2015 5:52 pm Up
As above has anyone tried ?
I've read about the gti 135 & 18bhp gains once the inlet is fitted..
Would the 2.2 throttle bodie work & all pipes there to join on??
Just an idea atm. Along with the 4-1 I fitted on gti if i fit that to the 180 might make a few more gains ..
There's no much I can do without spending £££
PostPosted: Mon Apr 06, 2015 3:55 am Up
No point on a 180.
Project2062014
PostPosted: Mon Apr 06, 2015 7:49 am Up
Edward wrote:
No point on a 180.
It's got a longer flow so with a 4-1 exhaust manifold it would give me better flow rates=bhp even if it gained 2 bhp it's a gain..
Would the Tb work off the ecu I'm guessing yes..
what's the compatability of the pipes ect with the ew12 /ew10j4s
PostPosted: Mon Apr 06, 2015 8:53 am Up
Try it then. As it's designed for a bigger car and taller block it will hit the oil filter housing and the radiator.
=ZiAn=
PostPosted: Mon Apr 06, 2015 4:49 pm Up
Well if you want to try I've got one for sale Very Happy
ZianDesigns - Website designs
Project2062014
PostPosted: Tue Apr 07, 2015 11:26 am Up
Is it a metal one or plastic? is it all complete no missing parts?
Do you have the throttle bodie aswell?
Price?
Cheers
tRiCk
PostPosted: Tue Apr 07, 2015 4:54 pm Up
lol hey I also have one for sale on eBay atm, I don't think it's worth it thou. The Rad gets in the way, the throttle body wouldn't work with the 180 Ecu, could be that it just was not working when I bought it. also the diameter of the throttle body is smaller in width compared to the 180's
Project2062014
PostPosted: Wed Apr 08, 2015 12:04 pm Up
Does the 180 throttle body fit the manifold ?
Did you have any troubles with oil filter housing? .
oldskoolz
PostPosted: Thu Apr 09, 2015 2:19 am Up
needs an adapter plate made, wont bolt straight on. it WILL foul against the oil filter housing unless you cut some material off
Black 206 Gti. Soon to be 2.2
Misio
PostPosted: Thu Oct 01, 2015 4:48 pm Up
anyone knows which one is better for GTI 138 ? I have atm Ew12j4 inlet manifold with Xu10j4rs TB but im not sure if GTI180 manifold isnt better.
PostPosted: Fri Oct 02, 2015 12:47 am Up
Go for the one that fits. ..
Misio
PostPosted: Fri Oct 02, 2015 4:06 am Up
I have ew12j4 manifold on my engine atm Smile But dont know which one is better. Found some posts that gti180 isnt so good while ew12j4 is nice one.
Misio
PostPosted: Fri Oct 02, 2015 4:10 am Up
Edward do u think stock intake will be enough for 170-180 maybe 190 BHP ? I have pipercross panel filter and modified intake according to this guide 206gti.net/intakemod/
But XU10j4rs TB is way bigger than stock so maybe i should buy big filter and make CAI ? Maybe Simota airbox or pipercross ?
PostPosted: Fri Oct 02, 2015 4:22 am Up
I would imagine if the original plastic manifold was good enough for 180 bhp Peugeot would have used if for the gti 180.
Misio
PostPosted: Fri Oct 02, 2015 5:23 am Up
Im using ew12j4 manifold not GTI 138. My question refers to intake. Is stock intake ( plastic box with pipercross panel filter) enough for 170-180 BHP ? Or maybe should i use big filter inside that box and make something like that
www.google.pl/search?q...4iC77PM%3A
www.google.pl/search?q...uMN-AoM%3A
