Forums › The Car › 206 Problems › 2005 HDI GTI |
Posted: Mon Oct 12, 2015 10:31 am |
Hi,
Had my car serviced today and asked the chap to check out my rattling noises, suspension wise.
Front and rear passenger side shocks are leaking. That would explain the loose handling I've been noticing recently.
Typically it had to just be on one side, so i'll have to replace all 4!
What is the best brand to go for? I've had KYBs on my MR2 before but they are a bit harder than stock, but that's obviously a different car...
What do people suggest?
Cheers
Posted: Mon Oct 12, 2015 10:58 am |
Can anyone tell me if I have oil on the rear and gas on the front or oil all round?
Posted: Mon Oct 12, 2015 11:08 am |
OE genuine Peugeot ones would be the best dampers to fit.
Posted: Mon Oct 12, 2015 12:39 pm |
Mine were oil filled I think. Bit sloppy as standard.
Posted: Tue Oct 13, 2015 3:31 am |
Is there any issues with changing to gas filled?
