Latest: dreyfalon
Overall: 17121
Online Now [535]:
Visitors: 534
Today: 11814
Total: 97538163
Forums › The Car › 206 Problems › GTI Loosing oil . . .
Lateral_Soup
PostPosted: Tue Nov 03, 2015 11:23 am Up
Im loosing quite a lot of oil (1litre a week) ive checked all the gaskets i can see and ive cleaned the engine to see if I can locate the leak. it seems to be coming from the lower back part of the engine and mainly on the gear box side. it doesn't appear to be coming from the cylinder head or head gasket and its deffinately not the rocker gaskets. its done 110k, im drawn to it maybe being the crankshaft seal? can anyone tell me if this is a common fault or if there is any other common issues with leaks that it might be?? thanks in advance for any advice =]
PostPosted: Thu Nov 05, 2015 2:20 pm Up
If it was crankshaft seal you should see it leaking from the bottom of the gearbox. Not a common problem,but it went on my GTi.
Lateral_Soup
PostPosted: Fri Nov 06, 2015 6:54 pm Up
It does seem to be coming from that area :-/ is it a big job to replace?
