Forums › The Car › 206 Problems › Dig A/C Not lighting up when headlights on |
Posted: Fri Nov 20, 2015 3:21 pm |
Hi All as per the subject, i have a 206 and the Digital A/C display and controls are not lighting up when the headlights are switched on.
Ive checked my headlights on Main beam, dipped and also the sidelights, there's no issues with the lights but when my headlights are on, the dash in my 206 doesnt light up.
The Multi Function display lights fine, its just the Dig a/c display.
the cars an X reg 206 GTI
Any help greatly appreciated.
Posted: Fri Nov 20, 2015 3:43 pm |
No lights at all? Or it dims? The bulbs might be blown.
Posted: Sun Nov 22, 2015 7:34 am |
There's only 1 bulb inside it so its probably popped, there's 2 in the screen though
Posted: Thu Nov 26, 2015 4:14 pm |
Cheers guys, it does light up but very dim. I was only able to get led bulbs locally and that hasnt fixed the issue nut ive bought some actual bulbs as opposed to LED's so will try them at the weekend.
