Posted: Sun Nov 08, 2015 3:40 pm |
Aloha to all to all viewing this
The air condition of my pug206 is consuming a lot of gas. I went to the A/C specialist and they tell me all is well with it, no leakages found but it always run out of A/C gas every one and a half month.
Do any one experienced similar fault and come to my rescue please.
Posted: Mon Nov 09, 2015 12:15 am |
Aminu wrote: |
Do any one experienced similar fault and come to my rescue please. |
Don't know of anything else that'd cause an A/C to loose pressure like that other than a leak...
Has UV dye been added to the system? Have you/they looked around using an UV light?
Did they pull a vacuum on the system, and test by letting sit for a while to make sure it's held?
| Silvermetallic 2004 206 RC | |
Posted: Tue Nov 10, 2015 3:20 am |
Well to fix this problem,I'm going to ask you a question,and your answer will be the fix of this,according to what you said,the A/C gas only last a month an half,right?
Is that with you using the A/C on daily basis or you discover it's not working when you need it?
Waiting for your answer.
Posted: Tue Nov 10, 2015 5:51 pm |
Probably my A/C is always on as far as am in the car.
Posted: Wed Nov 11, 2015 1:53 pm |
always on or not... it should last much longer then that, you must have a leak.
Get the leak tracing dye put in it.
Posted: Thu Nov 12, 2015 9:19 am |
You need to replace the A/C compressor as it's the one that leak the gas when it's working.
Posted: Sat Nov 28, 2015 2:19 pm |
Thank every one for all the advices. the problem is now quarantined.
