Latest: sparrowdclxvi
Overall: 17139
Online Now [179]:
Visitors: 178
Today: 47305
Total: 113656015
Forums › The Car › 206 Problems › sluggish and using too much fuel
burdy
PostPosted: Mon Nov 30, 2015 2:41 pm Up
hi I have a 1.2 206 04 plate, car runs fine in normal use but is drinking fuel at an alarming rate, there seem to be starvation of fuel or air when you accelerate and the exhaust seems over loud. car has been serviced, fitted new coil pack and been on diagnostic machine but nothing showed up. there are no warning lights showing and starts first time everytime.
David1156
PostPosted: Tue Dec 01, 2015 2:42 pm Up
Lambda sensor or hole in the exhaust?
Current: Albi Blue Clio 197
burdy
PostPosted: Wed Dec 02, 2015 11:31 am Up
thanks, whole brand new exhaust/cat fitted sesor looked ok and no warning light or codes showing
sloposse
PostPosted: Wed Dec 02, 2015 4:34 pm Up
Could be something to do with the lambda as it controls the fuel mixture and it sounds like its max fueling but try running it momentarily with it disconnected and see if there is any difference.
Does the car stink of petrol? If petrol has entered the exhaust it will have destroyed the catalytic converter internally and the brick inside will have possibly collapsed and blocked up the hole.
