Online Now [919]:
Visitors: 918
Today: 209532
Total: 152601787
Forums › The Car › 206 Problems › 206 Cutting Out
206 Cutting Out
TattyWater
PostPosted: Tue Nov 24, 2015 3:45 am Up
Help !!
My 99 plate 206 keeps cutting out !!
I seems that it only does it once it reaches normal running temp.
When driving along the power just goes and the car starts to slow, if I dip the clutch all the ignition lights come on, lift off the clutch and it bumps straight off and I can continue driving.
I have also noticed, when driving there is a sudden drop off in speed when you take foot of the accelerator pedal, then it slows more gradually as you would expect.
It has also randomly started revving from 1k to 2k on tick over.
There are no codes on the ECU
I have tried a new Map sensor, fitted a new Crank sensor, changed the throttle position sensor.
Any idea's much appreciated.
Mike
Motorracingbruce1980
PostPosted: Tue Nov 24, 2015 4:17 am Up
Hard to say without looking but would clean out the throttle body and all air intake. Without knowing what engine yours has but sounds like idle control valve symptoms or even an air leak
Project China Blue 206 GTI
TattyWater
PostPosted: Tue Nov 24, 2015 4:27 am Up
I'll take it off and give it a clean tonight.
I did take of the air intake and spray the inside of throttle housing with carb cleaner, weather it was coincidence or not but the car was much worse after, cutting out lots.
Totally fine tho morning on the short journey to work !
I believe the engine is HFX ?
TattyWater
PostPosted: Tue Nov 24, 2015 8:34 am Up
Don't know if it make a difference, but when power goes while driving, nothing happens when I press accelerator pedal.
PostPosted: Tue Nov 24, 2015 9:22 am Up
Id consider checking the throttle position wiring and sensor, also check the lambda sensor
TattyWater
PostPosted: Tue Nov 24, 2015 12:30 pm Up
I was also thinking lambda sensor, I have read that they're ignored by ecu until engine up to temp, which would tie in with my problem.
TattyWater
PostPosted: Wed Nov 25, 2015 1:26 am Up
Well swapped the Lambda sensor, thought it has sorted the problem as drove 17 miles with no problem, but no it cut out again !
I think I will clean out throttle and idle valve on Thursday evening, see if it makes any difference.
TattyWater
PostPosted: Fri Nov 27, 2015 8:16 am Up
I have changed the throttle sensor checked wires, swappped lambda for a used one I have had in a box of bits in garage for a couple of years. No change !
Should I try with lambda disconnected?
gingerninja500
PostPosted: Mon Nov 30, 2015 10:12 pm Up
Hi my 03 peugot 206 was working fine and battery has gone dead and has now gone into eco mode and wont start . what do i do ???
PostPosted: Tue Dec 01, 2015 8:37 am Up
Charge or replace the battery making sure you follow the correct procedure for reconnecting.
