Posted: Mon Dec 07, 2015 10:11 am |
Hi,
Can anyone tell me what are these 4 connectors used for?
I have tried the male connector to the headlight connector but 1) the battery drains itself after 3-4hours and 2) I have no idea what the wires do because the headlights already have power from a different source.
As for the female connectors.. I do not know why they are not connected where they should be connected as the car was like this when first bought.
www.dropbox.com/s/v6rr...n.jpg?dl=0
www.dropbox.com/s/26ow...n.jpg?dl=0
Posted: Mon Dec 07, 2015 10:44 am |
Front fog wiring and Headlamp level adjustment I think
Posted: Mon Dec 07, 2015 12:11 pm |
The grey 3 pin connector is for the crystal twin H7 headlamp.
The grey 2 pin connector is for the front fog lamp.
What headlamps are currently fitted to the car?
Posted: Mon Dec 07, 2015 12:43 pm |
If you look at the second picture you can see the empty headlamp socket on the back of the headlamp ...
so I would guess they are the standard single H4 bulb headlamps and this car has the multi-purpose loom ...
Posted: Mon Dec 07, 2015 6:29 pm |
The car has the standard H4 headlights but the H4 headlights also have a connector on the back of them where the 3 pin wire can connect too.. I did this and it just drained the battery instead :l and my 206 doesn't have front fog lights.
