Posted: Thu Aug 23, 2018 6:58 pm |
After a bit of advice, i have fitted a new bottom hose to the 180 but it's leaking from the seal! the hose comes with one rubber o ring but am i right in thinking there's another seal on the same hose before going into the radiator ?
Posted: Fri Aug 24, 2018 7:36 am |
Does this help?
Where are you fitting the seal?
Posted: Sat Aug 25, 2018 12:31 pm |
Yes massive help, cheers mate it looks like number 6 is the part i need to order and hopefully that'll sort it
Posted: Tue Sep 04, 2018 6:32 pm |
The radiator is the part leaking where the bottom hose goes into the radiator the plastic seems to be slightly stretched causing the o'ring to not seal correctly! Has anyone fitted an aftermarket alloy radiator to aid better cooling ? seen as though i am changing it anyway may as well have an upgraded one. Can't seem to find one though seen as though the bottom hose slides inside the pipe and is held in with a metal clip seems to make finding an aftermarket one for the 180 near impossible to source.
Would i have to fit a GTI one and just get a custom hose made ??
Posted: Wed Sep 05, 2018 8:20 am |
Standard car only needs a standard radiator. Isn't it the same as a 138 gti ?
Posted: Wed Sep 05, 2018 12:07 pm |
AS per ServiceBox: 138 and 180 both use same rad (as does 2.0cc CC)
1330 G6 ENGINE RADIATOR NEW UP TO OPR 09491 1323 22(1) JUSQU’A OPR 09491 1323 22(1)
1333 20 ENGINE RADIATOR EXCHANGE - AGE >= 2 UP TO OPR 09491 1323 22(1) JUSQU’A OPR 09491 1323 22(1)
Posted: Wed Sep 05, 2018 7:43 pm |
Ah right i see so must just be the bottom hose that's different. I'll just replace with a standard one
