Posted: Thu Dec 17, 2015 1:18 pm |
My daughter owns a peugeot 206 hatchback its a 1.4i and 2001 but every time I try to get bits on ebay I have to tell a porky and say its a 2000 because the only variants I get are the diesel 1.4HDi anyone know why??
Also the little torque link on the gear selector linkages popped off, its so loose I want to obtain the whole set but again one is available at ebay but only seems to fit the ruddy HDi's Grrrrrr
Posted: Thu Dec 17, 2015 3:50 pm |
Difference between manufacture date and registration date?
Posted: Fri Dec 18, 2015 6:30 am |
Phone a dealer and ask (you may find the parts are cheaper from them anyway!) or look it up on servicebox ... public.servicebox.peug.../index.jsp ... create yourself an account
I've just looked at the parts for a 1.4i 75 bhp and compared to my 1.4HDi and the gear change parts appear to be the same ... but there are three 1.4i versions under 3-door: TU3A, TU3JP and the 16v Twincam engine, and change to the five door and it is added to by the TU3AF version ...
But actually all 1.4s seem to use the same gear change components ...
Posted: Fri Dec 18, 2015 9:31 am |
Thats for a be4 gearbox not an ma...
| Team Impossible Possible
Posted: Fri Dec 18, 2015 10:56 am |
I've PM'd Tony .. so I'll check properly when I get some more info .. and BE4 was common to all 1.4 engines in servicebox ...
There are also MA boxes with rods like the BE4 and cables .. ??
Posted: Fri Dec 18, 2015 1:40 pm |
The OPs car will be a MA gearbox with rod linkage setup.
Posted: Sat Dec 19, 2015 6:39 pm |
Yes TU and MA box's use the same linkage, Like the BE gearbox all use the same as well bar the 180 which is cable
| The Pug Tuner and quality parts supplied
Engine & Box rebuild, Race, Rally, Track car's the only thing we don;t do is general servicing | |
Posted: Sun Dec 20, 2015 4:53 am |
Then next chance I get I'll replace linkage diagram with MA version ..
MA version gear-change now shown in previous post ...
