Online Now [243]:
Visitors: 241
Members: 1
Today: 67989
Total: 156587884
Forums › The Car › 206 Problems › Gearbox
Gearbox
Deano
PostPosted: Sun Dec 27, 2015 12:18 pm Up
Hi I have a 206 Gti 140 02 reg sorry for not knowing the proper words but right at the bottom of my gear box right in front of the radiator they is a paddle it looks like if I press my clutch it presses something into the gear box it's just below the bleedle nipple well what has happened is the bit what gets pushed into the box has come out of the bit that pushes it into the box and leaked all my brake fluid out all over witch has gave me know gearbox I can't seem to get the bit that's hanging out of the box back into the other bit so does that mean box out? Will it go back in with a bit of persuasion ? As much help will be much appreciated thanks lads
cainw1
PostPosted: Sun Dec 27, 2015 4:55 pm Up
Sounds like the clutch fork, but I don't know if it will pop back on
gazza82
PostPosted: Sun Dec 27, 2015 6:10 pm Up
If it's gone that far over for the slave cylinder to pop, you could need a new fork/arm, thrust bearing or pressure plate ...
Deano
PostPosted: Mon Dec 28, 2015 2:02 pm Up
So if I got a 3 piece clutch thrust bearing the box will be ok I could just take box out change it over and it be ok or will I need a new box the thing what comes out of the box is off the pedal and leaking fluid it feels hard to push back in thanks for help mate
