Latest: lio94
Overall: 17181
Online Now [102]:
Visitors: 101
Today: 36017
Total: 141533346
Forums › The Car › 206 Problems › coolent fan not working
sambelsher
PostPosted: Sun Jan 24, 2016 12:59 pm Up
hi I was driving the car today and could smell some thing burning like a wire burning smell then I notice the coolant temp had gone right up u pulled over turned car off and opened the bonnet and something was caught in the fan stopping it from turning and now the fan is not working at all I checked the fuse and that is fine would I need to replace the fan or the fan and whole fan surround
PostPosted: Sun Jan 24, 2016 1:30 pm Up
Could be the fan motor has burnt out.
If you have Peugeot Planet you can test the fan easily enough.
PostPosted: Tue Jan 26, 2016 11:06 am Up
What He Said
or you can unplug the temp. sensor plug,that will make the fan start when you turn the ignition on,this way you can be sure if the cooling fan working or not
