Forums › The Car › 206 Problems › Spring Cups |
Posted: Sun Mar 20, 2016 4:33 pm |
Any opions Please.
Changing both sides, front Springs, Shockers, upper mounts next week, only thing i am missing are the cups, where the top of the springs fit into.
As far as i am aware, (searched) these can only be got at the main dealers, unless someone knows different, £56 at dealers for pair.
Is it normal to change these, or will the old ones surfice.
| 206 2ltr Hdi glx 53 plate | |
Posted: Mon Mar 21, 2016 1:48 am |
If them aren't corroded then they are fine for reusing.
Posted: Mon Mar 21, 2016 1:42 pm |
Mmmm kinda stuck on that answer Edward, in Scotland all this week, and am away from the car.
my mates doing the work on the car Friday when I get back.
If I buy them from dealers as a back up plan, do they reimburse you if parts are not used.
