Posted: Fri Feb 05, 2016 10:03 am |
so i need a new comm2000 unti, i have an airbag fault =(. Basically i can get a second hand one from fleebay but will i need to get it reprogrammed? the car is a 2003 GTI 180? Or can i get one off a GTI 180 and plug and play?
Posted: Fri Feb 05, 2016 10:19 am |
It is plug & play BUT the ESP steering angle sensor is part of the com 2000 unit.
You should have this reset after replacing the unit.
Ideally the wheel alignment should be done & at same time reset the steering angle sensor.
Peugeot Planet required.
Posted: Fri Feb 05, 2016 10:30 am |
thanks mr bsi! my local garage has a snap-on SOLUS Ultra Scan Tool any idea if that will be able to do the job?
Can i also ask what damage or symptoms it will show if i do get this steering angle sensor reset? its mot runs out in few days and will it pass if this hasnt been reset?
Posted: Fri Feb 05, 2016 12:22 pm |
Incorrect steering angle sensor setting can scrub the tyres out.
No idea on if the Snap On can carry out the task.
Snap On diagnostic kit isnt the best out there, the name sells it
Posted: Fri Feb 05, 2016 12:49 pm |
I dont have my car at hand at the moment does anybody know the part number for a 2003 gti 180 com2000 unit?
big ask i know lol but thanks to anyone who can help
Posted: Fri Feb 05, 2016 1:53 pm |
Guys, the steering wheel sensor has nothing to do with tyres consumption. You have just to set it to zero with aligned steering wheel, with car standing still. It just says the ESP how much you are steering, to check if the car is understeering or oversteering in comparison with the yaw (not sure if it's the correct translation) sensor located under the seat (driver one in LHD).
| Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror | |
Posted: Sat Feb 06, 2016 7:18 am |
tommyb32 wrote: |
big ask i know lol but thanks to anyone who can help |
I've replaced a completely shattered Com2000 from my GTi 180 04-plate with one from peugeot 807 HDi 06-plate, by just googling the long number under barcode, and getting a good ebay deal for £80. Buying second hand is always a risk, but description and photos looked decent on that one.
Every Com2000 with ESP steering sensor will fit, but question is what other features you want , like auto lights, wipers, trip computer button etc. New ones cost from £150 to £300, and functions are usually drawn as little icons at the corner of the product photo (e.g. if you go to eurocarparts, put your reg and look steering wheel control/stalks unit)
You are guaranteed to get the same functions, if you source the same barcode (and best matches online, as opposed to the few ones by Peugeot's part number instead) I got lucky and got cruise control stalk in addition (i think I'll need more machinery to enable that one)
