Online Now [861]:
Visitors: 861
Today: 298114
Total: 150591649
Forums › The Car › 206 Problems › When I turn left oil and handbrake light comes on
HMKW93
PostPosted: Tue Feb 09, 2016 11:29 am Up
Ok so every time I turn left my oil and handbrake light comes on. I have checked my oil and brake fluid levels but they are fine... What is going on? I have a 1999 206 1.4 petrol. HELP ME!!!!
PostPosted: Wed Feb 10, 2016 11:47 am Up
it better be checked,as you might have oil pressure sensor fault,and usually the handbrake light goes on if the brake fluid level sensor is faulty as well.
HMKW93
PostPosted: Wed Feb 10, 2016 2:33 pm Up
Ok thanks do you think it will be expensive? And is it normal to happen only when I turn left?
PostPosted: Sat Feb 13, 2016 4:49 am Up
not it not expensive,the oil pressure sensor brand new is cheap and you can fit it yourself if you know the basics.
