Online Now [1030]:
Visitors: 1030
Today: 212568
Total: 152604557
Forums › The Car › 206 Problems › P0382 Glow Plug Circuit B
gazza82
PostPosted: Wed Aug 29, 2012 10:03 am Up
Anyone had this before and what did you do to fix it?
It's a 1.4 Hdi ....
Going to try it again later but this was from my Sealey code reader as I couldn't get PP2000 to work this morning ...
gazza82
PostPosted: Wed Aug 29, 2012 3:07 pm Up
Update: Tested again with PP2000 and it looks like a relay may have died. On testing I can only hear one operating ...
I'll take the covers off at the weekend and see what's what ...
Also getting a intermittent error on a clutch pedal switch .... what is that???
gazza82
PostPosted: Fri Jul 12, 2013 1:46 pm Up
P0382 is back and it depends on the system you use or website to read as to the answer ...
Normally most sites the Glow plug circuit as I first posted in this thread, but using PP2000 and my note book seems to suggest the EGR valve ...
So ... any bets on which one?
gazza82
PostPosted: Thu Jul 18, 2013 7:03 am Up
Anyone had any problems with glow plug circuit B on a 1.4 hdi and can tell me what they did to fix it Question
It's now stuck in limp mode so can't use the car ... and need to try and pinpoint something to start with.
Control Box?
Wiring?
I think the relays are OK as I can here them activate with PP2000.
gazza82
PostPosted: Wed Jul 24, 2013 9:09 am Up
OK, replaced the Glow Plug Controller Unit (5981-38) for the modest price of £54.73 from Peugeot dealer. This was comparable or even cheaper than some replacements from ebay and other suppliers.
All codes now cleared and eml switched off and running properly now.
gazza82
PostPosted: Sun Nov 02, 2014 7:35 am Up
And 15 months later .. P0382 is back and permanent.
Not in limp mode though .. back in July 2013 that was a red-herring as my Cat had also collapsed, so lack of power was down to exhaust being blocked, not glow plugs ... bit P*ssed it has only lasted 15 months though ... may have words with my Peugeot dealer tomorrow!
jaaquo
PostPosted: Thu May 26, 2016 12:06 pm Up
did you find a solution to this in the end?
