Online Now [818]:
Visitors: 817
Today: 268374
Total: 151745276
Forums › The Car › 206 Talk › Key Button Replacement?
Forum Index › 206 Talk
d4funky1
PostPosted: Fri Feb 26, 2016 4:35 am Up
Hello Again,
The 206 I purchased has come with 2 keys. 1 is a standard key for using on the door locks and the other is the remote central locking key.
This key will open the car with the door locks no problem but the rubber no longer exists over the buttons you would press to both lock and unlock the car remotely.
Is this something that is easy replaceable or is this a case of a new key and reprogrammed?
Thanks in advance
D4
FrankAteMyName
PostPosted: Fri Feb 26, 2016 6:26 am Up
You'll need a new case and that's all. If you open up your existing key, you will notice 3 main components: Circuit board, blade, transponder. Get a new case off ebay or wherever and transfer all 3 over. The transponder can be easy to miss but it is necessary. Make sure you do this somewhere you're not going to lose the darn thing if you drop it. They have a habit of disappearing forever. Only tool you'll need is a small Philips screwdriver to open the key.
My cars:
206 Urban 1.4 8v 3dr '56 - China Blue - 70k Miles - Climate control retrofit, cruise control retrofit - Dead (Breaking)
206 GLX 1.4 8v 3dr '03 - 100k Miles - Obsidian Black - Black masked headlights + front fogs, Faster sunroof, Colour matched exterior trim - SOLD
206 2.0 GTI 138 '03 - 58k Miles - Onyx Black - 17" 180 Alloys - Current
206 2.0 GTi 138 '03 - 120k Miles - China Blue - New Track Toy (ON THE WAY)
d4funky1
PostPosted: Fri Feb 26, 2016 8:12 am Up
Looks like the little metal switch is missing from the green circuit board.
I take it there should be two.
Can these be replaced, what are they called to search for?
Thanks again
D4
mtempsch
PostPosted: Fri Feb 26, 2016 9:46 am Up
Thanks again
D4
Something like 'peugeot 206 remote switch' on eBay should find what you need...
There are folks selling kits with case, battery and 2 switches too. Price roughly dependent on how fast you want it (where it ships from, UK/Europe/Asia).
Replacing the switches requires soldering SMD components. They're large as SMD stuff go, but rather small if you've only done through-hole soldering before.
You might want to look at some SMD soldering tutorials on youtube and then decide if you'll need to find someone to do it for you or try it yourself.
Silvermetallic 2004 206 RC
d4funky1
PostPosted: Fri Feb 26, 2016 10:15 am Up
Thank you.
I've ordered the kit (UK based) £3.93 delivered. This one had the Peugeot logo on the back as well.
I've got a guy who's a demon on the soldering iron.
Thanks again
D4
d4funky1
PostPosted: Mon Feb 29, 2016 6:28 am Up
Hi,
Key parts arrived today.
Switched over the transponder and new battery, soldered the micro switches and into new case.
Works like a charm.
D4
