Latest: TigerHunters
Overall: 17144
Online Now [64]:
Visitors: 63
Today: 8004
Total: 115881312
Forums › The Car › 206 Problems › Barttery replacment intermitent starting
cade199
PostPosted: Sun Jan 31, 2016 4:58 pm Up
hi all got an issue with a starting after replacing a dead battery,
rac checked the old battery :
battery ran a volt test on the alternator / battery.
only the batery loosing charge.
car did intialy start firts turn the key after fittin the new battery this morning.
now have an issue where the car will not start untill around 30 -40 seconds and usually requires a good amount of foot on the acellorator to start it will try to turn over during this wait period.
have read on others thread about a conneciton to the gearbox earth - not yet checked this unsure where this is located - could you provide some help with this.
fault appears randomly will someitmes start first turn.
car is standard - no mods
model is roland garos 2002 multiplex .
looking for some advice on thuis , when the battery died last nyt the alarm went off before.
tryed searchin through threads and cant seem to find a fault like this. all be it the slow loading of the work pc.
thanks
cade199
PostPosted: Sun Jan 31, 2016 7:14 pm Up
issue only seems to occur at present if the car has been running for a while , then turned off and re started say within half hour. car been sat at work for 4 hours just gone to start strated first turn. could you please help to define checks that i need to do. got three days off work and need to get my hands dirty and show this pug some love in that time .
cade199
PostPosted: Fri Feb 05, 2016 4:56 am Up
has no been resolved by correct battery reinstallation process n bsi setting ,
gazza82
PostPosted: Fri Feb 05, 2016 5:11 am Up
Gearbox earth is UNDER the battery tray/box. It's probably easier to take the box out to get to it.
Is the new battery OK?
If you are still losing charge on a new battery, the battery is duff or you have a power drain (boot light permanently on, etc?)
PostPosted: Fri Feb 12, 2016 6:53 pm Up
Poor hot restart and requirement to allow car to cool before starting often points to crank sensor but this seems too coincidental with battery change to be anything other than battery / electrical connection.
cade199
PostPosted: Mon Mar 21, 2016 6:16 am Up
cheers for the quick reply , have this sorted now turns out there was a short circuit , near the ignition as the pervious owner made a poor attempt at wiring an amp direct to the ignititon. cables removed and now starts like a beaut.
