Latest: Mr-Koekwaus
Overall: 17125
Online Now [316]:
Visitors: 315
Today: 58199
Total: 99824767
Forums › The Car › 206 Problems › Spring Cups
Spring Cups
DREWDEN
PostPosted: Sun Mar 20, 2016 4:33 pm Up
Any opions Please.
Changing both sides, front Springs, Shockers, upper mounts next week, only thing i am missing are the cups, where the top of the springs fit into.
As far as i am aware, (searched) these can only be got at the main dealers, unless someone knows different, £56 at dealers for pair.
Is it normal to change these, or will the old ones surfice.
206 2ltr Hdi glx 53 plate
PostPosted: Mon Mar 21, 2016 1:48 am Up
If them aren't corroded then they are fine for reusing.
DREWDEN
PostPosted: Mon Mar 21, 2016 1:42 pm Up
Mmmm kinda stuck on that answer Edward, in Scotland all this week, and am away from the car.
my mates doing the work on the car Friday when I get back.
If I buy them from dealers as a back up plan, do they reimburse you if parts are not used.
