Posted: Thu Mar 31, 2016 2:39 pm |
I fitted a new thermostat housing last week and overtightened one of the three bolts. I have a hairline crack next to the bolt hole and water is escaping
out of the housing. Any ideas how i can seal this crack or any other ideas.
Posted: Thu Mar 31, 2016 2:57 pm |
Replace the cracked housing & torque the bolts up correctly.
Posted: Fri Apr 01, 2016 12:05 am |
Definitely replace. Might also help if you post details of the car you're working on.
Year, Engine, Mileage, Recent work done, pre or MUX, etc.
I say this as some of them have plastic coolant housings and others have alloy
| My cars:
206 Urban 1.4 8v 3dr '56 - China Blue - 70k Miles - Climate control retrofit, cruise control retrofit - Dead (Breaking)
206 GLX 1.4 8v 3dr '03 - 100k Miles - Obsidian Black - Black masked headlights + front fogs, Faster sunroof, Colour matched exterior trim - SOLD
206 2.0 GTI 138 '03 - 58k Miles - Onyx Black - 17" 180 Alloys - Current
206 2.0 GTi 138 '03 - 120k Miles - China Blue - New Track Toy (ON THE WAY) | |
Posted: Fri Apr 01, 2016 2:12 am |
If its alloy like the GTI then it can be welded but it then distorts with the heat. It then needs machining to straighten the mating surface. Better just to replace it.
Posted: Fri Apr 01, 2016 3:54 am |
It is possible to plastic weld the other type but I wouldn't consider it a long trem fix. Plastic welding is nice and simple though and a cost-effective bodge.
I totally agree that replacing is the best way to go either way.
| My cars:
