Latest: DanDan17
Overall: 17128
Online Now [50]:
Visitors: 49
Today: 11273
Total: 100438989
Forums › The Car › 206 Problems › GTi 138 issues - Oil leak & Hesitation
FrankAteMyName
PostPosted: Thu Apr 21, 2016 7:55 am Up
Hi all,
I've picked up a cheap 138 ('03, 3dr, mux, 58k) and it appears to be leaking oil onto the drive. I will have a good lock tonight in the hope of finding it but are there any parts of the engine that are prone to leaking?
When you plant the throttle it tends to hesitate as well. Feels like what I would imagine a misfire would feel like but I have no experience with this. Any advice would be much appreciated.
My cars:
206 Urban 1.4 8v 3dr '56 - China Blue - 70k Miles - Climate control retrofit, cruise control retrofit - Dead (Breaking)
206 GLX 1.4 8v 3dr '03 - 100k Miles - Obsidian Black - Black masked headlights + front fogs, Faster sunroof, Colour matched exterior trim - SOLD
206 2.0 GTI 138 '03 - 58k Miles - Onyx Black - 17" 180 Alloys - Current
206 2.0 GTi 138 '03 - 120k Miles - China Blue - New Track Toy (ON THE WAY)
FrankAteMyName
PostPosted: Thu Apr 21, 2016 11:44 am Up
UPDATE: The oil smells suspiciously like petrol so I assume piston rings or head gasket have gone.
I also think the gearbox is the culprit of the oil leak due to the distinctive smell of old lathe.
EDIT: Oil seems to be leaking from passenger side of the gearbox.
Any suggestions would be marvellous.
UPDATE 2: Another limp home today - Seems worse when cold. Also was given antipollution and catalytic converter fault. The cat was new 1 month ago.
My cars:
Indigo_GTI
PostPosted: Sat Apr 23, 2016 5:24 pm Up
not a huge amount of places for leaks on the passenger side of gearbox fortunately. i'd check the driveshaft seal first as its the most likely culprit
FrankAteMyName
PostPosted: Sat Apr 23, 2016 5:28 pm Up
Narrowed it down to the driveshaft seal last night but thanks for your reply. Getting the cylinders pressure tested in the morning and hooking up the diagnostics. Could be the coil pack playing up and I hope it is because these faults are driving me insane.
G3 synchro to be replaced and a cv joint and then that leaves the mystery airbag fault and the engine issues.
Getting there slowly
My cars:
FrankAteMyName
PostPosted: Mon Apr 25, 2016 2:19 am Up
Update:
Cylinders were all pressure tested and it's good news. Removed the idle control valve and EGR and gave them both a good clean.
Faults given were:
- Random cylinder misfire
- Misfire on cylinder 4
- Idle control valve short cicuit
- Driver's seat airbag
I've had them cleared and will hook it up to planet now I have my new laptop. Seems suspiciously like coilpack to me but will change sparks firt (although they seem in good condition). Anyone had any issues with bosch super 4s? They're the ones that are currently in there.
Also changed oil and filters while it was on the ramp. Level was quite low so hopefully it will stay topped up. Only visible leak was from passengre driveshaft seal.
My cars:
Sim
PostPosted: Mon Apr 25, 2016 3:22 am Up
Hey congrats on good news!
That's the gearbox oil leaking there, don't change it until you've sorted in a new seal
EV
Jag S(crapped)- & X-Type
GTC VXR (sold)
FrankAteMyName
PostPosted: Mon Apr 25, 2016 3:27 am Up
Thanks for your reply. I was aware it was gearbox oil due to the smell. Sorry my wording is often far from perfect lol
Will be sorting the grinding through the gate of G3 while I'm down there. We also have a strange suspension/steering/transmission noise going on. It's sort of a clunk when you lift the clutch. Sometimes it happens when going over uneven road surface as well. I'd be tempted to say a CV joint but there was very little play in them so I'm now inclined to say otherwise?
Any ideas?
My cars:
FrankAteMyName
PostPosted: Tue May 03, 2016 10:40 am Up
Anyone who's interested - The misfire was fixed by fitting a second hand coilpack (£15 from breakers). Unlocked so much more power! It's a genuine pleasure to drive now Smile
Suspension/Drive noise turned out to be a gearbox mount
Leak fixed with new driveshaft/gearbox seal
Grinding still there (Assuming synchro)
So still some work to do but it's stable in the mean time Smile
My cars:
BradyBunch
PostPosted: Fri Oct 21, 2016 6:54 am Up
Got a similar misfire issue. Just out of curiosity where can I find the idle control valve and EGR? 138 engine also.
