Online Now [419]:
Visitors: 419
Today: 2495
Total: 154030314
Forums › The Car › 206 Problems › Hollow clunking noise in rear
PEUGEOT206DR
PostPosted: Fri Apr 22, 2016 8:48 am Up
I am hearing a hollow thump in the rear when entering or exiting a driveway. The sound is not constant. The car seems to dampen fine while driving and if i shake the car or push down on the rear the noise is not present. Visual inspection yielded no results. Rear brakes are in perfect condition.
lezyrider
PostPosted: Mon Apr 25, 2016 2:35 pm Up
Try looking at the rear wheel hub locating arms that run from the centre of the car out to the rear hubs at the end of the trailing arms, there's a bush at each end and when they wear they clonk a bit. I twisted mine and could see metal touching metal when I did.
