Latest: Mr-Koekwaus
Overall: 17125
Online Now [75]:
Visitors: 74
Today: 1124
Total: 99426700
Forums › The Car › 206 Talk › I need help.on my 206 hdi 2001 model 1.9cc
Jmc986
PostPosted: Sat May 21, 2016 7:40 am Up
The car was ok until it cut off then I started it it run fine for 30 minutes but there was a strange noise from the gearbox when I press the clutch,then cut off again. I could smell the clutch burns when I checked underneath. Now the car wont start. Diagnostics was showing a fault on primary fuel pump circuit low.I changed the pump,diesel is now circulating.I check all the small fuses, Now there no faults,all the injectors are receiving.power.no engine light management.but still the engine is just cranking it will only start for a few seconds then sometimes raves itself if I put flamable liquid at the intake. What could be the problem.
