Latest: Mr-Koekwaus
Overall: 17125
Online Now [449]:
Visitors: 448
Today: 19031
Total: 99444566
Forums › The Car › 206 Problems › Central Locking
Central Locking
zorro180
PostPosted: Wed May 25, 2016 2:55 am Up
Hi Guys, I have just acquired a 206 GT Grand Tourisme, my central locking is playing up. Every time i lock the car with the remote key it automatically unlocks and will not stay locked, this happens with all the keys. Any ideas guys
PostPosted: Wed May 25, 2016 5:26 am Up
One of the solenoids in the doors has gone which is making the locks bounce.
zorro180
PostPosted: Wed May 25, 2016 5:28 am Up
could this also include the boot
206gt160
PostPosted: Wed May 25, 2016 12:12 pm Up
How would we know which specific solenoid has gone.. or is it literally trial and error and buying a whole working set
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
mtempsch
PostPosted: Wed May 25, 2016 2:15 pm Up
One method 'I've seen mentioned here: unplug one at a time and see if the ones still connected then work correctly.
Silvermetallic 2004 206 RC
zorro180
PostPosted: Wed May 25, 2016 3:29 pm Up
cheers, are they easy to get to, I'm not mechanically minded lol,
PostPosted: Thu May 26, 2016 5:58 am Up
Sometimes the button on the door that contains the dead solenoid don't move when the key fob is pressed, although not an entirely reliable method of seeing which has gone.
Yes the tailgate one can go.
Remove the door cards and then you get access to the inner workings of the door and can get to the solenoids.
Tailgate one is simply the panel on the inside of the tailgate. It just pops off with a bit of pulling.
