Latest: Worthy967
Overall: 17143
Online Now [524]:
Visitors: 523
Today: 129902
Total: 115160892
Forums › The Car › 206 Problems › BSI
BSI
danielvella
PostPosted: Thu May 26, 2016 8:37 am Up
Hi I have a problem with my 2005 206. I had an ecu fault and replaced with a second hand one. Than I also had to replace the BSI because the engine was turning but not running because of the immobilizer. However since changing the BSI some of the functions were not functioning. Managed to fix these issues except the rear wiper, ac, interior central lock button and alarm. Now I have information that these fault can not be fixed because the BSI that I installed is of an older version of the 206. Is it possible to re install my original BSI and do something about the immobilizer?
PostPosted: Thu May 26, 2016 11:30 am Up
Depends. Give some info on the year of the car and model.
PostPosted: Wed Jun 01, 2016 1:06 pm Up
Well usually when you have a problem with the ECU,and you need to replace it to fix it,you need to buy a set ( ECU+BSI+KEY),and the donor car should have the same feat. as your car do,regarding engine size and model,some function can be configured using PP2000,but if the model is older than your car,it might not be working as the electrical system might be diff.
So the best solution is to get your BSI and ECU back,and get your ECU fixed at BBA or similar companies,OR have another set from a matching car as yours.
Good Luck
