Latest: heikkisj
Overall: 17126
Online Now [59]:
Visitors: 58
Today: 14107
Total: 100386825
Forums › The Car › 206 Talk › Gearbox oil specs
Gearbox oil specs
kernel
PostPosted: Thu Jun 09, 2016 12:58 pm Up
Hi guys
Have to replace the gearbox oil. What brand is the Peugeot OEM ?
Im wondering if use a 75w90 castrol its ok
Thanks!
EuroPeugeot
PostPosted: Thu Jun 09, 2016 1:02 pm Up
Check your handbook if you have it. But I used 75w90 and didn't run into any problems. This was used on my GTI 138..
kernel
PostPosted: Thu Jun 09, 2016 1:14 pm Up
Ive just read 75w80 is better option...
206++
EuroPeugeot
PostPosted: Thu Jun 09, 2016 1:17 pm Up
I don't know much about oil, but IIRC the numbers represent how the oil reacts at different temperatures. So it's actually all dependent how you're going to drive and the outside temperature / weather
PostPosted: Thu Jun 09, 2016 5:22 pm Up
Stick with 75/80
southwestchap
PostPosted: Fri Jun 10, 2016 1:15 pm Up
This would be near on OE:
Total Gear Oil
cainw1
PostPosted: Fri Jun 10, 2016 3:10 pm Up
Total 75w80 just changed mine for that and it is silky smooth. Remember to change it when the oil is warm but careful not to burn your hand!!
kernel
PostPosted: Fri Jun 10, 2016 4:49 pm Up
Yeah,will use total 75w80. Can i change the oil only using a jack to lift the car? Dont know how (un)accesible is the screw to remove the oil
206++
cainw1
PostPosted: Fri Jun 10, 2016 7:00 pm Up
Yeah you can I just jacked mine up took wheel off. You can reach under the front of the car without lying under it and undo the drain nut. My advice would be to take the filler nut off first though to make sure you can fill it back up!
kernel
PostPosted: Fri Jun 10, 2016 8:13 pm Up
thats a good point, thanks!!
206++
