Online Now [654]:
Visitors: 653
Today: 5066
Total: 150091968
Forums › The Car › 206 Problems › 180 occasional non start
iancav6
PostPosted: Sat Jul 09, 2016 8:39 pm Up
2004 180GTI 88k miles.
Occasionally,mostly when up to temp,go to restart it and although cranks over fine it refuses to start.Back the key off and try again and 9 times out of 10 it will fire up instantly.Today however it took 3 attempts more to start.
Once fired up it runs normally.No ecu light comes on,have checked for fault codes and nothing comes up.
Plugs are fairly new,air filter is fine.
xx
cainw1
PostPosted: Sun Jul 10, 2016 8:36 am Up
Sounds like it could be coolant temperature sensor. Changed this on mine and it improved startup drastically
gpvecchi
PostPosted: Sun Jul 10, 2016 12:31 pm Up
I remember there is an infoflash regarding the wiring coming from the ignition switch. If you want to PM me your VIS number, I can check if your car is involved...
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
iancav6
PostPosted: Mon Jul 11, 2016 7:16 pm Up
Replaced coolant temp and crank sensor tonight,see how it goes.
xx
