Latest: ArtistKS
Overall: 17145
Online Now [102]:
Visitors: 101
Today: 18720
Total: 115891777
Forums › The Car › 206 Problems › Central Locking working in opposite....
Bruiser
PostPosted: Wed Aug 17, 2016 8:08 pm Up
Hi 206 colleagues out there.
I recently asked for help on my Central Locking problem, and am once again seeking help or advice on the following fault.
My 5 door 1.4 HDI year 2004 works fine other than when I exit the car and open the drivers door using the release lever. The other 3 doors and boot then immediately lock themselves. I then have to operate the central locking keyswitch to open these 3 doors and the boot.
I have re-set the BSI (disconnecting/re-connecting the vehicle battery) to no avail.
Any help or advice would be most gratefully appreciated.
PostPosted: Fri Aug 26, 2016 7:36 am Up
I believe that you have a problem with the master central locking lock,which cause the others to work in opposite way.
So does your car close the central lock when you move,like auto lock?
Bruiser
PostPosted: Thu Sep 08, 2016 5:06 pm Up
Hi.
The central locking does not auto-lock when moving. The fault only happens (central locking activates and locks the other 3 x doors) every time I exit the driver's door by operating the internal door release handle.
I should add that the system is fine and is not activated if someone is sitting in the opposite side and exits the N/S/F door.
