Forums › The Car › 206 Problems › type of bolts for headlights and grille? |
Posted: Sun Sep 18, 2016 4:29 pm |
I appear to have lost a couple of bolts while letting my headlights get tampered with over the years.
I may as well replace these and the rusty old ones that i still have.
Does anyone know the spec for the bolt so i can buy online?
Posted: Sun Sep 18, 2016 5:01 pm |
Go to the Peugeot dealer.
