Latest: elelectricistadeMateo
Overall: 17127
Online Now [61]:
Visitors: 60
Today: 22676
Total: 100395353
Forums › The Car › 206 Problems › Peugeot 206 2002 esp problems
shopy
PostPosted: Wed Oct 05, 2016 9:42 am Up
hi there experts
i need help on my 206 2002 gasoline .
the esp light is constant on and i cant erase it with lexia. lexia say it is a coherent fault.
i checked all the fusses and i checked visually the right abs sensor and clean it.it did not help.
are there more then one abs sensor on this car?
i rely do not know what to do more?
thanks for advice
PostPosted: Wed Oct 05, 2016 10:31 am Up
2002 & ESP?
Are you 100% sure your 206 has ESP fitted?
shopy
PostPosted: Wed Oct 05, 2016 3:16 pm Up
no im not.
but the lexia say u1213 esp function that cant be erased and the light is constant on.
i refer this problem to the ABS system.but im not sure?
do any one know how meny abs sensors are on 206 2002
thanks
PostPosted: Wed Oct 05, 2016 6:35 pm Up
There is one on each wheel. What does the light look like that's lit?
shopy
PostPosted: Thu Oct 06, 2016 8:04 am Up
it looks like car slips and 2 half circles in both sids
shopy
PostPosted: Thu Oct 06, 2016 8:12 am Up
www.google.co.il/url?s...1499688848
like this
pAvax
PostPosted: Thu Oct 06, 2016 8:15 am Up
ABS:
Dynamic Stability:
Edit: ABS that is Smile
Current project: Ciri
Silver 206cc - 2.0 - 2001
shopy
PostPosted: Thu Oct 06, 2016 10:29 am Up
it is very interesting i unplugged the connector from the abs unit and start the engine .and the abs light is still on?? how can it be???
can it be that the problem is in my dashboard lights unit and the abs is ok.??
i checked all the sensors with a multi meter and got 4 readings almost the same so i assume the sensors are ok.
any good idea ???what can be the problem??
pAvax
PostPosted: Thu Oct 06, 2016 10:47 am Up
I reckon that if you unplug one, it won't get the readings from that unit; making it a fault automatically.
Unfortunately I am not well versed in ABS systems and what commonly causes faults on the 206.
Did a search though, as I am interested in the fix myself. Did see the following:
pug206lx wrote:
Could be dirty/corroded/cracked rings, could be sensors... Don't get wet carpets do you? I had this problem in my 406 and it turned out water had gathered in the sound deadening below the carpet and had slightly corroded the plugs in the footwell. After taking them apart, drying and cleaning them the problem went away.
www.206info.co.uk/Foru...45994.html
And a few more mentions of a cracked ABS ring.
PostPosted: Thu Oct 06, 2016 11:20 am Up
Was going to suggest pushing the car slowly by hand. If you can hear a metallic rattle it might be the trigger rings on the driveshafts.
shopy
PostPosted: Sat Oct 08, 2016 9:34 am Up
ANY MORE EXPERTS??????
PostPosted: Sat Oct 08, 2016 1:15 pm Up
Have you read the fault codes?
shopy
PostPosted: Sat Oct 08, 2016 3:08 pm Up
the only fault code i get is at the gear box ecu :u1213 esp function
and i can erase it.with lexia.
