Latest: DanDan17
Overall: 17128
Online Now [62]:
Visitors: 61
Today: 21814
Total: 100449508
Forums › The Car › 206 Problems › ABS indicates
ABS indicates
junooskp
PostPosted: Wed Oct 19, 2016 7:29 am Up
My peugeot 206cc 2004 model shows abs warning sign and its not starting when i tried to give ignition wipers on and lights blings last week i have changed the break disk and pads
pAvax
PostPosted: Wed Oct 19, 2016 8:29 am Up
Have you got access to an OBD-II reader? As this will potentially be able to give you some error codes and areas which might be worth investigating.
Current project: Ciri
Silver 206cc - 2.0 - 2001
PostPosted: Wed Oct 19, 2016 10:51 am Up
if the ABS pump is faulty,car won't start,best thing to get a PP2000,read codes,and start from there,this way we can help you,it might be something very simple,as an ABS sensor...you never know.
PostPosted: Wed Oct 19, 2016 2:36 pm Up
With the amount of faults all happening at the same time I would suspect a battery or battery connection problem.
PostPosted: Thu Oct 20, 2016 9:34 am Up
That or maybe a short wire in the engine harness,which causes the warning lights to be on.
