Posted: Mon Oct 31, 2016 2:21 pm |
Starting to look very good, im hopefully out in mine on the 9th of November at snett if your about!
| Team Impossible Possible
Posted: Mon Oct 31, 2016 5:14 pm |
nice progress mate, make sure to get some pics up of the cage, be good to see where the mounting points are
Posted: Mon Oct 31, 2016 8:44 pm |
pAvax wrote: |
Get plastic windows with the slides you can open. Also takes weight down, as glass is heavy. Poly carbs are about 70 quid I believe. |
I was going to look into these over the winter, any names of company's ? Thanks
Posted: Mon Oct 31, 2016 8:48 pm |
Just finished photos of pre cage prep, removed the small amount of sound deadning from the rear footwells so I can get the floor painted once back.... and to save a couple kg's haha
Posted: Mon Oct 31, 2016 8:50 pm |
MattyP wrote: |
nice progress mate, make sure to get some pics up of the cage, be good to see where the mounting points are |
I will be sure to get some decent pics up, the mounting points are front floor roughly inline with edge of dash, back of rear footwells and third of way down boot floor. Will report back at end of week with plenty of snaps
Posted: Tue Nov 01, 2016 10:24 am |
Domparrott wrote: |
pAvax wrote: |
I was going to look into these over the winter, any names of company's ? Thanks | No sorry, only what Google tells me. They don't fit my car, so never really looked into them I am afraid. I only know of them and that at times they are required.
| Current project: Ciri
Silver 206cc - 2.0 - 2001 | |
Posted: Tue Nov 01, 2016 10:31 pm |
Do you weigh all the black tar stuff next to the coke can?
Looks good so far.
Posted: Wed Nov 02, 2016 5:11 am |
Still got all the air con stuff fitted? That's 10kg.
Posted: Wed Nov 02, 2016 9:19 am |
Edward wrote: |
Still got all the air con stuff fitted? That's 10kg. | Sorry to hijack!
Removing the air con stuff... does that trigger any issues with computer/BSI systems?
Posted: Wed Nov 02, 2016 9:44 am |
Not on my non multiplexed car it didn't. All the wiring was also stripped back to the ECU to tidy it up.
Posted: Wed Nov 02, 2016 11:10 am |
Edward wrote: |
Not on my non multiplexed car it didn't. All the wiring was also stripped back to the ECU to tidy it up. | Awesome.
As it will get rid of a radiator too, so space for a pulling fan. Who needs an aircon in a convertible anyways?
Will consider this as an opportunity too. Thank you Edward.
Edit: And thank you Pez! Seems like a nice next step to tidy stuff up and increase my mpg
Posted: Wed Nov 02, 2016 11:11 am |
Iv removed the air con and all gubins on my HDI and had no issues or warnings and that's a multi plexed pAvax.
Posted: Wed Nov 02, 2016 1:54 pm |
pAvax wrote: |
Edward wrote: |
Edit: And thank you Pez! Seems like a nice next step to tidy stuff up and increase my mpg |
Keep the standard fan. It won't leave room for a different fan.
Posted: Thu Nov 03, 2016 8:36 pm |
Just been and collected the car, too dark to take pics of all of it so took a few snaps of the welding just to show you all, will take some better ones tomorrow.
Posted: Sun Nov 06, 2016 3:55 pm |
