Latest: slaapkonijn
Overall: 17169
Online Now [164]:
Visitors: 163
Today: 68238
Total: 128660798
Forums › The Car › 206 Problems › Worrying clunk from wheels!
BradyBunch
PostPosted: Fri Nov 11, 2016 7:34 am Up
Hi guys, as I turn full lock to the right whilst moving (forwards or backwards) I get a loud clunk from the front right wheel area. Occasionally I get the same issue turning left but primarily it's when I throw alot of right steer on and it is getting worse.
206 GTI 138, 100K. Passed MOT last month.......
Cheers
Josh
Sim
PostPosted: Fri Nov 11, 2016 9:07 am Up
Top mount strut bearing if doesn't clunk when over potholes, otherwise it will simply be drop link. ask someone else to turn and put your ear over top mount plastic.
I found it was droplink once, I saw&felt its balljoint pop about in socket. Someone turn wheels and you observe the droplink. If get no visual movement, grab a hold of it during the clunk but mind your arms! Smile
Other way is to draw a metal bar from various suspension parts and your earlobe and stethoscope your way through Smile
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
gazza82
PostPosted: Fri Nov 11, 2016 5:20 pm Up
Could be the driveshaft joint .. they tend to be noisier when turning.
