Latest: kemppu
Overall: 17142
Online Now [69]:
Visitors: 68
Today: 21191
Total: 114060342
Forums › The Car › 206 Talk › 206 fault codes
206 fault codes
Fredo
PostPosted: Tue Nov 22, 2016 8:32 pm Up
Hi guys, got a bit of a problem with the 206 GLX (T1) 2003. Went to start the car and the fuel gauge went to empty with low fuel light flashing, there were verious light on in dash display and the mileage went -----. It was also flashing STOP. The car did start but display stayed the same.
when I now switch the ignition off and remove key, the display etc stays on and reading as above. The other strange thing is if I shut the door and leave car alone for 5 mins, display then goes out but when I open the door it comes back on again. Checked with diagnostics and got some strange fault codes, only had numbers ie 018D communication with cluster faulty. 0192 info display faulty and 0189 AC control unit faulty. These codes are not usual "P" codes. I am wondering if the body control module has gone down. Any help would be very helpful.
