Online Now [1120]:
Visitors: 1119
Today: 121616
Total: 150974476
Forums › The Car › 206 Problems › Fuel leaking from ......?
Targa180
PostPosted: Mon Jun 16, 2014 5:58 pm Up
Hey all, so my garage recently reaks of fuel all the time when the car is in it, something has a leak, all lines at the engine are dry and no imediate smell there, checked the filter just infront of rear drivers side wheel, no leaks there, so then i sprayed waterup under the car all around the fuel tank and it came out pretty colours on the concrete, so, there is a leak somewhere up in there. How much removing fuel tank could I be in for? common problem? I notice an inspection panel in under the rear seats, worth playing around in there searching?
All help appreciated as im going through fuel a tad quicker than id like to be aswell.
Matt
DanT
PostPosted: Tue Jun 17, 2014 1:56 am Up
I would imagine the most likely place would be where the filler neck meets the tank to be honest, i'd tempted to remove that and inspect it first. Does it always leak? Or only when 3/4 full or 1/2 full etc?
PostPosted: Tue Jun 17, 2014 6:44 am Up
The filler nexk attaches to the tank with a rubber pipe. Long term it could degrade. Always worth removing the inspection cover though to see what's happening on top of the pump.
PostPosted: Tue Jun 17, 2014 9:31 am Up
I've heard of a few 206's springing a fuel leak from the seal on the sender / pump unit.
Targa180
PostPosted: Tue Jun 17, 2014 12:05 pm Up
Roger, thanks chaps, I'll get into it. And yeah smells worse when full, actually I did 150kms on the highway yesterday and it dropped a notch on the gauge in 42 kms!
PostPosted: Tue Jun 17, 2014 2:54 pm Up
I agree! What He Said
Move the rear seat bench over,and remove the black plastic cover that covers the fuel pump,most likely there if where the fuel comes out,as there is a seal made of silicone,and this seal gets bad with the fuel vapor,so when you fill car with fuel,the fuel comes out from there,and while u move,,,,etc.
Targa180
PostPosted: Sat Aug 02, 2014 12:53 am Up
Ok so that seal looks dodgee, what part is it to replace? Can't seam to find one anywhere. Also noticed a sucking or hissing noise with car running when looking over the top of the tank when the seat is up and cover off. Does everyone's do this or is this noise my leak causing bit of a vacuum noise?
cosmicdance
PostPosted: Mon Aug 18, 2014 5:49 am Up
You might have to replace the whole plastic cover and that comes with a new seal.
I got mine from Europarts and it was cheap enough.
Andy
Andy
Lordsbe
PostPosted: Tue Jan 03, 2017 10:56 pm Up
leaking,I had petrol leaking from a hoselike object underneath 206 very near the fuel filter close to the right rear wheel area,please assist me solve the problem.Thanks.
