Latest: sparrowdclxvi
Overall: 17139
Online Now [146]:
Visitors: 145
Today: 29106
Total: 113477243
Forums › The Car › 206 Problems › Do hatchback doors fit sw
Sprints
PostPosted: Fri Jan 06, 2017 9:25 am Up
Hi Guys, after an accident I need to replace both drivers side doors on my 206 sw. Do the doors from a hatchback fit. Thanks
PostPosted: Fri Jan 06, 2017 9:44 am Up
Front will from a 5 door. Rears won't.
gazza82
PostPosted: Fri Jan 06, 2017 3:09 pm Up
One here www.ebay.co.uk/itm/PEU...Sw8oFXyUo7
The other idea is find someone breaking an SW on fleabay and email/call them ...
