Forums › The Car › 206 Problems › how to turn dashboard light on with pp2000 |
Posted: Thu Jan 12, 2017 7:08 am |
I had problem:
When driving with lights on, when I turn winker stick it will work briefly and turn off, or not work at all.
I remove wheel, remove comm2000, dismantle comm2000, and find not problem at all with winker swiches. Just in case I did clean them.
Light switch stick I didn't dare to dismantle.
Next I connect pp2000, and programmed "Running Lights" from absent to Present, so light is always on.
With that problem with winker cut-off is fixed temporary till I get new stick.
BUT background dash light is off all the time!
When I drive in night I can't see speed and rev.
Can I/how enable dashboard light with PP2000?
Posted: Fri Jan 13, 2017 6:39 am |
With programmed Runnig Lights, I can't turn High Beam on?
Posted: Fri Jan 13, 2017 2:48 pm |
j00j4nt200 wrote: |
With programmed Runnig Lights, I can't turn High Beam on? |
On a 3003 car in Sweden, as a prior version of DRLs, the dipped beam is auto-on (unless you turn light switch to sidelights only.
With lights auto-on (light switch in 'off'/0 position the instrument cluster backlight is off and the main beam are only momentary on (as long as you pull on the stalk, but will not remain on when stalk is released).
If I turn the light switch to 'on' the instrument cluster backlight comes on (and displays and buttons dims). Pulling the light stalk, past the detent, will toggle the high beam on and keep it on when stalk is released, until another pull toggles it off.
| Silvermetallic 2004 206 RC | |
Posted: Fri Jan 13, 2017 8:10 pm |
I understand now, thank you
