Forums › The Car › 206 Problems › 206 gti 180 Rear shock/damper help? |
Posted: Tue Jan 17, 2017 1:47 pm |
thanks for looking and thanks in advance for any replies
been looking for rear shock absorber for my 206 gti 180 loads come up but when i look for bilstein b4 i cant seem to find any.
i was wondering if the rear shocks same as on any other 206 ?
www.ebay.co.uk/itm/Bil...SwaNBUgDl5
Posted: Tue Jan 17, 2017 2:16 pm |
All the same fitting. Rate will be different to other 206s though.
Posted: Tue Jan 17, 2017 5:41 pm |
just ordered some, they should be ok if they fit. thanks for that
