Forums › The Car › 206 Problems › 206 cc What is this tube? (engine bay) |
Posted: Wed Jan 25, 2017 7:17 pm |
Hi, Just replaced the starter motor on our 2005 206 cc. I noticed this tube was out of its clip and gently pushed it back. Not gently enough as it was very brittle and snapped.
What is it called? Vacuum or pressure? Can I replace it with 'ordinary' tube?
Thanks in advance
Posted: Wed Jan 25, 2017 9:10 pm |
Looks like a breather pipe. Cut the hose off the connector where it's heat shrunk into place and stuck a silicone hose on instead. Cost about £5.
