Latest: S2cgm
Overall: 17178
Online Now [3161]:
Visitors: 3160
Today: 38201
Total: 136250286
Forums › The Car › 206 Talk › P0135: 02 Sensor Heater (lambda)
kernel
PostPosted: Sat Jan 14, 2017 11:51 pm Up
Hi guys
Recently the MIL light came on, and checking with OBD2 reader throws me that fault: P0135. Rolling Eyes
I would like to know if you think that the fault can only be caused by the sensor heater itself. I understand that the only solution would be to change the whole sensor? May be the fuse?
If I have to replace it, despite I chekced servicebox for location... could you tell me which is the easier way to replace the faulty sensor? It's an easy work to do? Confused
Regards
gazza82
PostPosted: Sun Jan 15, 2017 3:33 pm Up
What engine? Some cars have one sensor, some two.
Also if the heater circuit has failed, new sensor. There aren't any fuses afaik.
Note that the sensor and wiring is critical. So you can't just put any old sensor in their. On the two sensor cars one plug is light blue, the other light green and the wiring legnths are different and not just bevause of their position.
They are usually a pita to remove (several years being cooked). Using a proper lambda sensor socket helps.
kernel
PostPosted: Wed Jan 18, 2017 8:51 pm Up
Car is 180gti. So it has 2 sensors, faulty one should be the "before cat" sensor I guess. I have OEM number.
The think is; how to replace it? Its mandatory to lift the car?
I wonder if there's any guide for this operation.
206++
