Online Now [1027]:
Visitors: 1026
Today: 49347
Total: 128023306
Forums › The Car › 206 Problems › delphi diagnostic system on 206 gti 180
Peynut
PostPosted: Tue Mar 28, 2017 4:46 pm Up
is it possible to use delphi to bleed the brakes on my 206 gti 180. if so do you know how to or can you pint me in the right direction for a guide or is it something what i will definitely need peugeot planet for??
thanks for any replys and help
Sim
PostPosted: Wed Apr 19, 2017 11:21 am Up
Modern cars need their ABS pump primed to get rid of any air there. Delphi DS has that option as shown here, and you could have a go with someone in the know (they're the brakes mind! Smile )
This fella sums up the Delphi procedure quite well here: www.youtube.com/watch?v=FoA_4JPs3as
If you still have spongy brake pedal after it, then it really means Peugeot Planet is your last resort (find our member on PP2000 map nearby you and send them a message!)
The reason only PP2000 might help in the end, is because your 180 is equipped with ESP/ASR, and there are more moving parts involved in the brake system, that need scrupulous bleeding
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
