Forums › The Car › 206 Problems › 206 1.1 Fault code read |
Posted: Fri Jan 27, 2017 3:26 pm |
So I went to a garage today and had my car plugged into a decent code reader. It came back with various codes, about the temperature sensors, and also something to do with the speed sensors?
For now I'm going to try and replace all the temperature sensors possible and then go down the Crank shaft sensor route.
Please could someone tell me where the sensors are on a 52 Plate 1.1 petrol.
The Haynes manual I have is not clear at all, and I cant find any other media.
Many thanks,
Note: My car used to not start up sometimes, all the right noises just not firing, a couple of hours later it would start fine. Now It seems to start every time, but will occasionally cut out whilst driving with shudders at low speed.
Posted: Mon Jan 30, 2017 10:24 pm |
Can you list each fault? that will give us a good idea whats going on.
| 2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey | |
