Online Now [1108]:
Visitors: 1107
Today: 14163
Total: 151152685
Forums › The Car › 206 Problems › Coolant Leak
Coolant Leak
206HdiGti
PostPosted: Fri Apr 21, 2017 5:23 am Up
2005 1.6 HDI
Hi all,
Been a while since reporting a problem.
Randomly after about 30k miles I have had to top up my coolant yesterday. Thought nothing of it. But this morning had to do the same, and was missing more today than yesterday. Got to work and left it 10 mins to find a puddle under the middle.
Its not coming from the radiator, but its dripping from somewhere onto the subframe and ARB then onto the ground. Are they any coolant hoses running to the bulkhead from the front?
gazza82
PostPosted: Fri Apr 21, 2017 2:12 pm Up
The hoses that supply the heater?
PostPosted: Sun Apr 23, 2017 3:09 pm Up
maybe you have the main plastic pipe that drive water from the water pump to the thermostat housing cracked,or the thermostat housing itself is cracked.
Best way to check is to get the cooling system under pressure,using the special tool,and see where the coolant is leaking.
206HdiGti
PostPosted: Mon Apr 24, 2017 9:41 pm Up
It's coming from above the starter below the air filter housing.
I can se a water pipe missing it's clip. Don't know why this would suddenly start to leak though.
PostPosted: Sat Apr 29, 2017 2:18 pm Up
get the missing clip and see how thing goes,if it continue to leak,them you need to replace it.
