ok so i believe i may have an issue with the drivers side drive shaft / CV joint.
cornering has a few strrange sounds and when pulling away with lock on you can hear a clunk.
Upto about 40-50 there is a drone not a constant grwol like wheel bearing but more akin to a warped disc or similar rubbing, but vanishes above 50.
Is it best to change the entire drive shaft with the bearing on the mount or just do the joint?
cheers
